how do i get sound
how do i get sound
I have power to my amp from the stock HU but how do I get audio to the subwoofer without having a spot for the RCA plugs?
Please help!
Thanks
Please help!
Thanks
uhhh,.,, you totally want to get power to the amp directly from the battery, and not spliced from thin power wire @ HU harness.
the stock HU outputs at line-level, so you can get a 20$ lineout converter to convert it to RCA to plug into the amp.
I know how to hook up an amp. I have the power wire running from the battery the ground hooked up in the trunk and the remote wire spliced with the white/red wire.
I have an aftermarket cd/dvd HU on the way. I will just wait to hook up the sub when I get the HU. The HU has a subwoofer output.
I just was wondering if there was a quick way to try out the sub.
Yes, you can use a speaker level to line level adaptor hooked to the rear channels of your head unit. If you do not already have rear speakers, then the fader will act as a level control for the sub. If you don't use the level converter, the voltage from the speaker outputs from the head unit will be too high.
BerlinaBayRidah
08-01-2008 11:46 AM
