HELP Turn signal
HELP Turn signal
my passenger side turn signal is not working for some odd reason, But works when i turn on the emergency light. I checked the bulb its seems to look fine.. Fuse looks good. checked wiring.. all looks good. Cant seem to figure out what could cause this problem.. any helps guys/girls ?
TTonight while driving up highway both turn signals suddenly quit working emergency lights work and side markers work but when I flip signal stick it doesn't work green arrows don't even come up on dash like the actually stick stopped working but I can still turn on headlights and high beams with same stick WTF?
I haven't had this problem with my S2000 but on an old '75 Toyota I used to have, I once had *exactly* this problem, down to the fact that hazard lights worked but turn signals did not.
On the Toyota, the problem turned out to be corrosion on a ground wire for the tail lights. When I cleaned off all the corrosion, put on some dielectric grease, and bolted it back together, everything worked fine.
This may not be your problem, but it might give you something to look for.
