HELP: stock head unit replacement
There are lots of guilds on how to remove your stock HU on this forum. Just follow those steps to take it out and putting another oem HU back in should be cake, since you don't need a harness, its just plug and play. As for cost, why not see if another member on the forum would sell their oem HU. I'd sell you mine since I'm putting in a system soon but CA is a bit far from Philly.
1 Philips head screwdriver.... and about 20 minutes at the most in time. Its very easy.
Fully open the radio door.
Pull on the radio door itself. The radio door panel including the vents above the radio will pop off. 4 clips hold it on.
Then just unscrew that 4 screws and remove the headunit. unplug the harnesses and ant. cable.
Then just reverse the whole thing to reinstall.
