Help with stock head unit with Lucid's amp harness output to amplified
I ordered Lucid's pre-amp harness for the stock head unit. The output to the amp seem to be very high. My amp shutdown if I turn the volume to high level. Is Lucid pre-amp harness send pre-amp level or regular radio level output to the amplifier? Is there anything can be done? Thanks,
Does Lucent's harness come with a Speaker-level -> Pre-Amp level unit(s)? Just wondering..
(If NOT, then you need to convert your output's to pre-amp levels using a PAC or similar... available anywhere-- Circuit City, Best Buy, etc...)
-- Aaron
-- Aaron
What does the remote-trigger do-- mute the rears for '00 and '01 models? Just wondering...also, can you post a pic of the PAC-2 OEM? (Is there a difference from PAC-2 and PAC-2 OEM?)
Thanks Lucent!
-- Aaron
Thanks Lucent!
-- Aaron
[QUOTE]Originally posted by amartin
[B]What does the remote-trigger do-- mute the rears for '00 and '01 models? Just wondering...also, can you post a pic of the PAC-2 OEM?
