HELP! No RPM Display?
i was wondering if you can help me...
i was wondering if anybody here has the same problem...
basically... im trying to figure out why my tach is not working.. no rpm display..
but interesting is on a initial start up the tach works but when the car is running and im revving the engine theres no display... what could be my problem? any help would be really appreciated.. thanks...
theres an engine check light due to i removed the immobilizer..
[media]http://www.youtube.com/watch?v=Pi9dlHNZprY [/media]&feature=player_profilepage << engine revving no display
but like i mentioned with the key on "ON" position the cluster starts up with the rpm display all the way at 9k rpm..
[media]http://www.youtube.com/watch?v=K1YypzbFHxQ [/media]&feature=player_profilepage << initial start up showing the rpm working...
Try posting in the Under the Hood section. There are a lot more people in that section that will most likely be able to help with your problem.
Good luck!
Good luck!
s4play
06-15-2004 02:45 PM
