Help with New System
I just installed a new sound system in my S about a week ago. So far I have:
HU: Alpine iDA-X001
Speakers: Focal K2 Power 165 KF
Amp: Alpine PDX-4.150
It sounds great, but I have come to the conclusion that it needs some more bass and am looking to add a sub into the mix. I have a couple of questions:
1) Does my amp have enough power to power a 10"-12" sub?
2) Which sub(s) would you recommend?
If it helps any, I will probably be enclosing this sub in the trunk well, as most people do. I looked through the FAQ and used the search feature, but still couldn't find what I was looking for. Sorry if this is painfully obvious; I'm still learning the ropes here
Thank you for your time
HU: Alpine iDA-X001
get your sub enclosure from here http://www.darksidesubs.com/ . A lot of people run these and I also plan on getting one. They recommend a 10 or 12 inch alpine type R sub for the enclosure but you can get whatever sub you want. I am not sure if your amp has enough power for your sub. I'm sure an Ej will chime in. Good Luck
i have the same amp and ordered a box from darksidesubs. contact wlaurent as that is his site. he was very helpful in addressing my questions. i ended up going with the alpine type-r 10" in a tw enclosure. it should be arriving this week.
I think you should be fine with the PDX-4.150 amp. I have one also which will power Focal K2P components and a JL sub. I know and have seen at least 3 others that use this amp alone to power a pair of components and bridge channels 3 & 4 for the sub on this site.
Thank you for your help with all this.
To answer your question bent, it works really well from what I can tell. The best part about it is the fact that it is so small, a huge plus with a car as small as the S2000. You can also stack a couple of them on top of each other off to one side of the trunk without having a problem with them fitting. I only have one, but the Alpine website says it's possible and certainly looks possible from the size of the amp and the dimensions of the area. I got mine from Car Toys for around $600 I think. Up there in price for sure, but its small size sold me on it. I would recommend one to someone looking for an amp.
i had 3 pdx amps in my old civic si... 2. pdx1.1000 and 1 pdx 4.150.... the 4 channel amp that you have will not be able to handle the subwoofer along with the interior speakers... you would have to pick up another amp...thats a personal opinion... i think the crossovers and sound of the amplifier arent meant for a sub... let alone the power... and also i dont believe the channels on the pdx 4.150 are bridgeable... if someone has bridged that amplifier... they have it incorrectly hooked up
Originally Posted by shenanigans,Feb 13 2008, 02:49 PM
here are the bridged specs according to the alpine site for pdx 4.150
Brigded 4 ohms: 300W x 2 (<=1% THD+N)
