Help with my gauges
Help with my gauges
Well i bought this a pillor and it came with a volt and af guage already in it. Gona use these before i go FI. but ok the volt works fine. The af gauge however is not working right. Black ( ground), Red ( power), Purple ( lights?), and a gray one??? I dont know where to wire the gray or if i wire the purple one right? I've tried the search button and its not really helping. Read one where it says to wire the purple wire to the c16 white wire going to the ecu. If i did that then where does the gray one go? Anyone can help it would be great....
The Air/Fuel gauge (assuming its the one with a bouncing LED) gets wired to your o2 sensor wire. I dont recall wether its the primary or secondary o2 that needs to be tapped, and I also dont remember what harness it is on. Hopefully someone will chime in, if not, Ill take a look in my manual, and let you know.
