Help! How to set up factory keyless entry remote?
I just bought a 2002 S2000 and only one of the keyless entry remote's works of the two provided. Does anyone know hot to set the remote. Please Help!!
I just had my local Honda dealer set an additional one [I recently received from another board member] for me. I can't say I have the *exact* steps down as I witnessed the service tech set it, but it looked like it could be repeated rather easily. Basically, what it seems he did was the following:
1. With keyless remote in hand, tech inserted key into ignition.
2. Turn ignition all the way over.
3. Press "lock" button on keyless entry.
4. Turn ignition all the way off.
5. Repeat steps 2-4 three times.
6. Repeat steps 2-5 for each of the other buttons (unlock button & trunk) on the keyless remote.
If all steps relayed above are accurate, then you should be able to step out of your car and the remote's lock will lock, the unlock will unlock, and the trunk release will release the trunk.
Good luck! If this does not work...lemme know & I'll double-check with my dealer again for ya.
- Dave
- Dave
