Help: Gauge Cluster Stop working!
Old 01-24-2006 | 12:16 PM
Ben-G's Avatar
Default Help: Gauge Cluster Stop working!
I was changing clusters due to scratches. So i pulled out my original cluster and plugged in new one, it was working fine. The I wanted to keep the same milage so i swapped out circuit boards. Then i plugged it in and it lit up (30 secs) then just turned off, the other cluster did not even light up. I then decided to put back the circuit boards to their original housing, still not working!
The weird things is that everything on the cluster functions except the readings which require sensor readings. My signals works, key icon, battery, and Handbrake. My backlights for night driving still work. But no RPM, Speedo, Gas, Temp!
It's not the fuse, and there is power coming out of the harnesses, so don't know what it might be?
Your help is be greatly appreciated!
Old 01-24-2006 | 01:11 PM
xviper's Avatar
Originally Posted by Ben-G,Jan 24 2006, 02:16 PM
It's not the fuse
Are you sure? The gauge assembly is powered by 3 different fuses.
Old 01-24-2006 | 01:54 PM
Ben-G's Avatar
[QUOTE=xviper,Jan 24 2006, 04:11 PM] Are you sure?
Old 01-24-2006 | 02:34 PM
xviper's Avatar
They are all under the dash. They are #5, 23, 25.
Begin counting from left row, bottom (#1). When you get to the top (#13), come back to the bottom and continue with the right row (#14).
Old 01-24-2006 | 05:48 PM
darkknight1999's Avatar
Sounds like fuses to me as well.
Old 01-24-2006 | 06:34 PM
Ben-G's Avatar
I checked the fuses all good! I noticed that now the only light i get is battery indicator.
Any other ideas?
Old 01-24-2006 | 07:05 PM
Your gonna have to start testing to make sure your still getting the feeds from each circuit.
BTW those scratchs on the clear face of the cluster can be polished out. I've done it...
Old 01-24-2006 | 07:43 PM
Ben-G's Avatar
I tried scratch was very deep, too deep to buffout
How do i check the feeds?
Old 01-24-2006 | 07:58 PM
You need a digital multi-meter. Do not use a test light. You have to get a Helms and find out what goes to what. It won't be easy.
Old 01-25-2006 | 03:40 PM
dbzerk's Avatar
Have you jump started the car or done anything electronical to the car prior to this happening?
J2G Autosports
10-06-2010 11:10 PM
MoogieBoogie
11-23-2009 10:37 PM
cubide
07-06-2007 01:29 PM
NSRsinfuLangeL
04-04-2006 10:06 PM
S2K
05-05-2003 09:48 AM
