help fuse keeping blowing out
ok... my fuse in the fuse holder that is connected to the battery with the power wire keep on blowing out... i have one 12 hooked up to an amp... the amp has a ground (to the chassis), the remote wire to the headunit (blue wire), and the powerwire that goes into the fuse holder that is hooked up to the battery. the fuse that is inside that fuse holder blow out everytime i turn on the radio. i checked all the wiring but everything seems right. the rca is connected to the headunit and amp and the sub is hooked up also.... i don't know what it is... help..??? suggestions...???
ensure you have the right size of guage of cable for the amp... as the amp might be drawing more then the cable is rated for, and thus the fuse is protecting the cable from burning out.
Cable size selection chart
AND
ensure you have the correct size of fuse for the guage of cable your useing that same link...
Let us know how that worked out for you
AND
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Also after u check your cabling is the right size and lets say it is.. If it still does it and u have the right fuse in the fuse block as well.. Then the amp is probully shorting out inside..
AND
AND
I am not sure where your amp is located in your car, but if you are useing the chart I posted, and your amp is in the trunk... I will assume you have an aprox distance of 12 feet (best case situation). Then 8 guage cable is only going to be able to handle 200Watts RMS. NOT 1000WATTS.
You might start a fire in your car. Is your amp rated at 1000W or 1000W RMS??? I highly suggest replaceing your amp with an amp that is rated for 200W RMS OR replace your cable with a 2guage cable that can handle 1000W. (cable being the cheaper route).
I have a 180W RMS amp...and I used an 8guage cable, manufacture said that 8guage was the MINIMUM I could get away with. Your playing with fire.
What size is your fuse???
