Help, Driver Window Auto Down Does Not Work???
The driver side window auto down does not work. The window will go up and down. But, the auto down does not work. I think its not the switch, coz when i put top down the driver side window only goes down about 2 inches. The passenger window works fine, it goes all the way down.
Is there a wire that my be loose? or a module that may be broken?
I bought the car used last year, the auto down didn't work then. Never thought about it much. Until i found this forum. I'm glad i got this car it was a toss up between an S2 or NSX. S2 deal came first. now i found out the S2 has a large community, its all good.
anyways so im not sure if under warranty. it only has 10,800 mi, but I'm not the original owner.
Please check on the reprograming. Thanks
Not that most people care, but the changing of the regulator involves dismantling your door and taking the glass out, changing the reg, putting the glass back in and calibrating the whole thing.
Until you get it fixed, you just have to learn to use the window down button in conjunction with the top switch.
Originally posted by Squeezer
emc2 sells autolocs that fix the problem permanently, even if your regulator is broken.
The "fix" no longer works with mine and I'm out of warranty. This autoloc thing sounds like the ticket for guys like me.
emc2 is the guy that sells the autoloc units, you will need 3 of them, he sells them for $25 each so you'll spend $75, which is cheaper then buying 3 of them from any other supplier. you can send him a PM or email, but when I PM'd him, he seems slow to reply. http://forums.s2ki.com/forums/member.php?s...nfo&userid=7099
also woodwork did the autoloc install and you can PM him,
http://forums.s2ki.com/forums/member.php?s...info&userid=467
all the info you need on how to wire them and such is in emc2's group buy (really old thread)
http://forums.s2ki.com/forums/showthread.p...ghlight=autoloc
also you can contact cornfish for info
http://forums.s2ki.com/forums/member.php?s...nfo&userid=7136
http://www.cornfish.com/S2000.htm has install instructions for the autolocs
just search for emc2 autoloc, you'll get plent of threads about the autoloc units.
i still have one of the autoloc boxes at home so if you want the model # I can get you that and you can order 3 from wherever (find a supplier on google I guess or a local car audio store prolly carries them) and the install instructions are on cornfish.com.
