HELP: Corner lights not working
I recently took my headlights out and both front bulbs (#194) were out of their sockets inside the headlight. They are push-in bulbs and don't fit very snugly. I suspect a LOT of s2000s have their parking light bulbs out. If this is your problem, you'll have to remove the bumper and headlights to get the bulbs out or you can replace the bulbs and leave the "extra" bulbs at the bottom of the parking light area.
You do not have to remove the bumper and headlights to get at the parkinglight bulbs. Just turn the wheel and pull back the splash guard after removing the retaining clips. You will be able to access the parking light sockets much faster this way.
Thanks a lot guys. I'll try it out. But I would like to first check out the fuse so I don't have to go through all that trouble. Do you guys know which fuse it is?
What The
54
01-29-2007 03:37 PM
