Headunit Installation
Old 03-27-2012 | 09:19 PM
bgioan's Avatar
Default Headunit Installation
I've searched but can find nothing that exactly answers my question. Tomorrow I am planning on buying either a Pioneer DEH-P9400BH or a DEH-P8400BH and I am curious as to whether or not I need a frame or mounting bracket to install the headunit or does it simply just slide into the same place where the OEM radio was?
Also for the wiring harness adapter, how exactly do I do it so that I don't need to cut the OEM wiring or will I be required to cut it? Thanks in advance for your patience.
Old 03-28-2012 | 05:30 AM
takeshi's Avatar
You're probably trying to be too specific with your searches. Read the DIY AP2 head unit install thread. You'll use the existing brackets and then pop on the trim piece once you're done.
You need a harness for the head unit and a harness for the car. Wire and solder the two to each other.
aiwlu
03-31-2012 04:44 AM
hook3549
12-21-2010 01:40 PM
hellspare
10-21-2008 01:15 PM
alex.stanley
11-05-2005 03:10 PM
seung
12-21-2001 05:14 PM
