Head Unit Harness Wiring - Rear Speakers
I can't seem to find it... but what are the correct colors for the Rear Left/Right speakers?
I keep finding this diagram, is it the same for 2008 as well?
Radio Constant 12V+ Wire: White/Blue
Radio Ignition Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Antenna Trigger Wire: Yellow/Green
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Green/Yellow
Left Front Speaker Wire (-): Gray/Red
Right Front Speaker Wire (+): Green/Black
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): N/A
Left Rear Speaker Wire (-): N/A
Right Rear Speaker Wire (+): N/A
Right Rear Speaker Wire (-): N/A
I don't know whether AP2s use the same colors in the factory harness as AP1s, but they
use the same connector, so you can use the chart on MacGyver's page which shows the
positions as well as colors to figure it out.
However, if you need to know in order to install an aftermarket headunit, I'd recommend
using an adapter harness like a Metra 70-1721 rather than cutting the car's harness. Note
that many adapter harnesses are missing the S2000-specific dash control wires. If you plan
on using a Modifry DCI, you can buy the proper harness from Modifry with all wires.
Battery WHITE/BLUE (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/GREEN (+) RADIO HARNESS
LF Speaker (+) GREEN/YELLOW
LF Speaker (-) GRAY/RED
RF Speaker (+) GREEN/BLACK
RF Speaker (-) LIGHT GREEN
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/RED
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Does any one know for a DBW AP2 if I can tie 4x6 speakers into the same wires going to the teeny tiny roll hoop speakers? Would I be better off tapping into the harness at the back of the head into, and using the above pin out diagrams?
