Grounding Head Unit
^^^ Thats what I would do, or if the slot on the harness you bought has an open pin on the slot that matches up with the ground on the factory harness, I would solder a pin on the end of the ground wire and insert it into the harness you bought (if that makes any sense to you)
It's likely an additional ground wire to ground the headunit's case.
You can just attach it to one of the screws that hold the headunit in,
it doesn't need to be the world's greatest ground.
