grounded screw under dash?is their one?
Im trying to hardire my passpot and cant find the grounded screw under the dash...is their one????
or do i need to go get a different lug connector thing and just crimp that onto the existing wire and then ground it to something in there bigger???
There is a very large grounding bolt with an "octopus" of ground wires going to it. Duck under the driver's footwell and look up at the fuse panel. Then look even further up onto the frame and you'll see that bolt. Just use a "T" tap into any one of those ground wires or you can crimp on a ring on the end of your ground wire and remove the bolt and add the new ring to the cluster. I've always elected to use a "T".
awesome found it...had to put a bigger bolt connector ground thing on the wire but got it...damn that hurt to get into that position though
its funny i was just at my car and was gonna hard wire my V1 Today.
Got all my tools and the hardware, then i opened the door and i had flashbacks of wiring my Boost controler and, turbo timer i closed the door put tools and hardware back in work truck and went back to bed.
You gotta be a freaking acrobat, i def wasnt feeling like playin twister today.
Marcus
Marcus
i find that if you're gonna spend any time doing any wiring in this car -- just pull the seats out, lay some pillows on the floorboards, then put your feet up by the roll hoops and your head under the dash, and do what you've gotta do.
The screw ain't coming off. I tried the pliers, flat head, drilling a hole in the middle, etc... Thing ain't coming off. Thanks to everyone for suggestions, anybody know where i can buy the brackets? Someone suggested it earlier, i tried looking on the net, but can't seem to find it. I guess i'll call the dealer tomorrow to see if i can get one.
Also, does anyone know if my warranty is voided because i replace the car stereo myself? Cause my friend's gf was like, "Oh my gosh, your warranty is not going to valid anymore because you messed around with the car." Kinda made me wince, cause i'm not sure. I guess i'll read the warranty agreement on that one.
I must really be losing it. What "brackets"?
