Which is ground, which is power?
Im hardwiring my escort passport with a telephone wire and i opened up the power thing for the cigarette light and found i need to use the green and yellow wires for power and ground, but i am clueless as to which is ground and which is power. Can anyone help me out?
As far as testing, if you take the black lead of your voltmeter and touch it to any metal part of the car chassis it will be grounded. Take the red lead, and touch it to one or the other wire to test the voltage of that wire. If it is powered, you will see ~12VDC; if it is ground, you should see 0VDC. If neither show a voltage, then either a) your accessory power is not turned on, b) neither wire is powered, or c) your ground lead is not grounded properly.
Good luck.
Mike
