getting headlights to always turn on
Hi, for all you electronic guru's out there would i be able to connect a wire to jump the headlights to the ignition so when i turn the key on the headlights automatically turn on?
so i would connect a wire with two female pins to E and C. would that work?
i believe headlight you will have to tap the wire.. I would use a fuse and relay to do it.. im not sure on the color of the wire for the headlights, maybe someone wit the schematic can chime in.
correction i found it blu/red is the wire for headlights in the steering column, its for a 2000 s2000 but most likely the same in all years, just test the wire.
