Fuse or "hot" wire when engine/ignition on in engine bay?
So as a follow up to my questions yesterday, I'm looking for a fuse or "hot" lead for ignition on in the engine bay. It's not going to power anything with a large draw, but simply trigger a relay...It looks like all the fuses are constant on, but not sure if I could tap into the actual relays in the fuse box or if you guys had any other potential advice. Thanks!
Please see Page 41 of the following: http://api.viglink.com/api/click?for...20-010v4.0.pdf
Hope that helps.
