Focal 165a1
Focal 165a1
So I just bought items for my sound system set up, first the pioneer headunit deh-6200bt, installed that with no problem. Then I bought focal 165a1 component speakers 6 1/2 took apart my stock speakers to find out that they go intoo deep, and the stock brackets don't fit? As well as the tweeters since the stock tweeeters has a hole where u can screw them, should I use doubled sided tape? And take the focal tweeters apart to make them fit? Has anyone installed these components in there car?
You should post this in the electronics section...Might get better responses. Using double sided tape generally doesn't hold well with the vibration from the car as well as from the sound output.
I have the Focal K2's with tweeters in my car, they did not have a problem installing, it fit like oem. Not sure how the structure on the a1's is different than mine.
