Extending system power wire
I was wondering is it bad to extend system wires such as my amp power wire and speaker wires? I want to relocate my amp but the wire is too short so i was wondering if i extend the wire is that bad? Will there be any power loss? My friend was telling its not good to do that cause there will be power loss. Please let me know. TIA
A good measure to know how much you're going to lose by extending wires is the voltage drop. Try this calculator:
http://www.bcae1.com/wire.htm
If it says you're ok, then you're ok. I can go into more detail if you want, but that should give you enough information to make the right decision. And if you really want to learn, check out www.bcae.com -- read through the modules. It's very good.
There will be power loss!!! But not much, probably not enough to be any kind of a problem your extending what? a few feet?
Nice link ace, I will have to bookmark that one.
It also depends on how you are connecting the extension (dont use wire nuts). I would use a fuse holder, perfect for connecting two cables and the added protection of a (presumably additional) fuse
http://www.crutchfield.com/p_211FHXL0/Stre...arch=fuse&ssi=0
NFRs2000NYC
10-30-2004 06:14 PM
