electrical problem................
so there SHOULD be lighting around the dials, right? since some point, i no longer had lighting around the dials and i even got used to not having it...
so i tried to fix it by myself and tried to lift the panel.... and it won't go back in!! (not to mention that i didn't even get to fix it) it's the trim if you know what i mean....
apologize for the quality of the pic... taken by my phone...
should i just take it to a dealership?
thanks!
thanks!
I would recommend taking it to a dealer. More then likely it could be a fuse problem. If it is more then that it will need to go to a dealer. Wiring is something that should be taken lightly.
Hope that helps
Dewayne
Hope that helps
Dewayne
While I would fix that myself if your not sure of exactly what your doing it might be best to run it over to the dealer and let them take a look. Its mostly likely a bulb issue or maybe a fuse but I would suspect the bulb first. How long have you owned the car? Did you buy it new?
As you can see from this pic, there is a (hole for a) retaining screw on the back that must be removed.
I can't see anything in the pic you posted.
You should either take it to a dealer or buy a service manual, so you don't break something.
-Pete
are you guys mad?? a dealer for a blown fuse or bulb - ...
i can see them saying "sure sir we can fix it for ten million dollars...
compliments of DJ Cube
http://briefcase.yahoo.com/bc/djqube21/lst...Control&.view=l
dude, i had the same exact issue with i took apart my dash. all i did was bang on it and the lights came on again. it happened 2 more times and i did the same thing. after that, i never had the problem.
