Door rattling after installing aftermarket speakers
Hi,
A while back I put in some aftermarket speakers:
https://www.onlinecarstereo.com/caraudio/pr...t.asp?sku=11412
anyway, on the driver side door, the trim piece for the door locks/power windows rattles at certain frequencies from the speaker. When I push down a lightly on this trim piece, the rattling stops. Any ideas on how to quiet the rattles?
Thanks
Thanks
I had the same problem. Take the door panel off. On the inside of the panel, the power window switch assembly is held on by a couple of screws. Unscrew and remove the switches. Take a couple of small pieces of foam/weatherstripping and stick between the switch assembly and the door panel. Re-attach the switches. Do the same thing to the plastic 'cup' that surrounds the door pull and lock switch.
