dome light on for seconds after closing the door?
Is it possible to delay the map lights so they go off couple of seconds after the door closes instead of shutting off right away?
I ask this because I am looking to wire foot well lights and door handle lights connecting them both to the dome light.
Originally Posted by Stealth_SUX_,Mar 24 2009, 02:52 PM
yep, dei makes a timer relay. you can integrate that into the circuit.
http://www.amazon.com/DEI-528T-Pulse-Timer...y/dp/B0009IR4AC
Basically its a adjustable relay..
Its activated by whatever means ie: the door opening.. And once activated it counts down a timer and will cut the circuit after the given seconds you put it to..
