Deiver's side window failed
My driver's side window quit working. I can hear a faint click when actuation the switch. The passenger window operates perfectly. I have checked the fuse under the dash for the dr side window, but it is fine.
I'm not sure if this is related - but the stereo is not working either. I've checked these fuses as well - they are good.
I need to get this resolved quick - I don't want to be banging my helmet on the window at the SCCA SOLO Nats!
Sounds like a bad switch or bad motor. Pull the door panel and power the motor directly to determine which.
I can't see any relation between the radio and driver's window. While the passenger window fuse covers some other circuits, the driver's fuse only feeds the power window switch in the driver's door.
