Cooling fan relay
Cooling fan relay
I'm at work away from the helms and need some help with a brainstorm I'm having. Does anyone know if the cooling fan, and condenser fan relays are switched to 12v, or switched to ground. Also, do you know which side of the coil is 12v and which is ground. Thanks.
Wouldn't matter either way. I was asking if it switches the power leg or the ground leg. I'm asking, because my teg switches the ground leg on a lot of circuits.
