CD reads and plays but no sound
just installed the unit and the cd wont make a sound, but as soon as i switch it to the tuner, it works fine.
radio harness wiring wise, i only have the constant accessory and ground hooked up. im using RCA's for the signal input.
could this be a problem with the actual headunit?
any help would be greatly appreciated.
B
B
i think i found the issue. its the remote wire. i have it hooked up to the unit side and i believe its the wrong wire. the radio works fine because i have it hooked up to the ant controller and instead of wiring to its actual remote wire.
our cars don't have a remote turn on since we don't have a factory amp. We do have a blue wire which is for power antenna. (this is for the Honda plug, not the Kenwood plug)
Also, even though you have the problem fixed, most Kenwoods have a brown wire in the harness. Make sure that wire isn't connected to anything that would supply a ground. It's the mute wire and will mute the radio(on any source) if it "sees" a ground signal. Just FYI.
B.C.
01-01-2006 10:52 PM
stockae92
01-16-2003 12:05 AM
