Car Receivers and Steering Wheel controls
Old 05-12-2010 | 04:30 PM
RXS2Ki's Avatar
Default Car Receivers and Steering Wheel controls
Hi all,
I'm looking to pick up a new receiver and wanted to get something that didn't require any additional hardware to get the steering wheel controls to work properly.
I was reading the write ups in the how to forums and there was mention of this however the article is a few years old.
Anyone have any recommendations?
Old 05-12-2010 | 05:11 PM
cpl9190's Avatar
If you mean you want a new head unit (Receiver) and want to keep the dash controls on the right you need to buy modifry's harness. I believe it is in the range of $90.
Old 05-13-2010 | 05:17 AM
takeshi's Avatar
You'll have very few choices if you go that route. I'd strongly suggest just finding a head unit compatible with the Modifry DCI. If you want to make the install as easy as possible then get a compatible Alpine head unit and Modifry's PnP harness.
I'm not sure why so many seem to call the DCI a "harness".
In the photo below the harness is on top. The DCI is on the bottom. The harness on its own isn't going to allow you to retain use of the dash controls.
Old 05-13-2010 | 05:59 AM
4forall's Avatar
the new Alpine 305s says it has the capability to work with "most" dash/steering wheel controls. you can start there. it even has a nifty usb plug/cable that comes with it to make attaching your ipod/iphone a breeze. as well as pandora radio friendly!!!!
Old 05-13-2010 | 09:01 AM
Ottercycle's Avatar
Eclipse CD5030 works most of the controls. search this forum, i posted a thread not too long ago.
Old 05-18-2010 | 12:05 AM
RXS2Ki's Avatar
I'm really Liking the CD5030 Ottercycle, It's hard to find anyone that still caries it but I found it on amazon.
Is there an updated version?
Old 05-18-2010 | 04:46 AM
takeshi's Avatar
Eclipse is shutting down. IIRC Fujitsu will still provide warranty support but you might as well strike it from your list of options IMO.
Also, IIRC the 305s still requires a DCI as do most head units that say they "work" with dash/steering wheel controls. The Eclipse is an exception though.
Old 05-19-2010 | 02:05 PM
Will's Avatar
PAC also makes an adapter that works, for less $$$. But it doesn't work as well as the Modifry unit, IMO.
Old 05-24-2010 | 09:07 AM
Ottercycle's Avatar
RXS - no, there is no updated model as per their tech support. the 5030 has the ability to "learn" the resistance values of the dash controls, so you are able to use everything except "mute" which is a voltage value. also the channel button works as "track" select for usb/cd and "seek up" in radio mode. unfortunately it does not switch thru radio channels in memory tho.
Old 05-24-2010 | 12:31 PM
yessamgerg's Avatar
just get an alpine headunit and modifry's plug and play DCI so simple and actually more functionality from the dash controls
Quick Reply: Car Receivers and Steering Wheel controls
