Capacitor needed?
Old 11-26-2012, 09:17 PM
Ragnarok043's Avatar
sure you can use a multimeter but i suggest using a clamp on type which can handle that much amps.
Old 12-05-2012, 06:07 PM
Pinky's Avatar
Originally Posted by Toms1989
Power caps = Biggest con going...
It's just another point to charge.
Best thing to do, upgrage the big 3, it's cheap as chips to do, a larger capacity battery, or a dry cell battery like an Optima Yellowtop
All it consists of is a larger AWG wire going from Battery to chasis, Positive battery to alternator, and engine to chasis.
Reduces light dimming, and in a nutshell a better flow of current.
Caps are NOT a Con. They have their place when using big subs to keep power from dipping as a car battery can not supply the amount of power needed to keep up with a hard thump.(instant split second power) If your not running a 12" or multiple 10's you probably don't need it.
Better battery like you say WILL help in the long run. Upgrading an alternator i probably the last thing you need to do. Bigger battery gives you longer/better power output to the stereo. I upgraded to an Optima in an old car actually helped the bass thump!
Upgrading the power wires from the alternator to battery is probably not needed either. If you are running a 4 aug wire long as the connections are good that should be more than enough!
As for FUSE just add up the max amounts on the amps and fuse at the battery for that amount. It has no bearing on what your alternator needs to be. If your dash lights dim as the bass thumps then you have to start upgrading.....if it's not then you are fine!
TheKleinschmidt
08-19-2012 10:35 AM
TheKleinschmidt
07-03-2012 01:31 PM
Red89gt
09-01-2011 07:41 AM
neoarroyo
08-06-2007 09:19 PM
hornyhonda
10-31-2004 10:34 AM
Quick Reply: Capacitor needed?
