Can someone look over my alarm wiring?
Hey, I'll be installing a Compustar alarm and I just want to make sure the wiring is correct before I go ahead with this. Please let me know! I'm really unsure about Connector 1 Pin 6 and Connector 4 pin 3.
Alarm computer pin: Function- color and location on car.
Connector #1:
Pin #1: 12V constant- White on ignition harness
Pin #2: This wire is the (+) positive parking light output- Blue wire on headlight switch.
Pin #3: This wire has to be connected to a constant power for the unit to function correctly- White on ignition harness
Pin #4: Accessory- white/red wire on ignition harness
Pin #5: This wire is the (-) negative when armed out. It will provide a (-) output anytime the unit is armed or remote started. This wire is pre-wired into the starter-kill. This wire could be used for adding a window roll-up.- NONE
Pin #6: This wire is the (+) Starter output. Blue/white wire on light blue 24-pin plug located left of column? Need to jump the clutch wire.
Pin #7:- This wire is used to power the (+) ignition. Both Black/yellow wire on ignition harness
Pin #8: This wire needs to be connected to a chassis (-) ground. Pick a bolt.
Connector #2:
Pin #1: This is the low voltage (-) parking light output 200mA. NONE.
Pin #2: This is the (-) Status Out wire. Transponder Module- NONE if you have EMS
Pin #3: This wire is the (+) 2nd ignition 200mA output. Black/red and Orange wires on ignition harness
Pin #4: This wire is the (-) 2 Accessory 200mA output. NONE
Pin #5: This wire is a (-) 2 Starter 200mA output. NONE
Connector #3:
Pin #1: This needs to be connected to the parking brake. This wire requires a (-) input to activate. Green/white wire on light blue 24pin plug left of column.
Pin #3: This is the (+) shutdown for the foot brake. White/black wire on brake pedal switch.
Pin #4: This wire is the (-) trigger input, which needs to be connected to a trunk pin or trunk trigger. Blue/black wire on white 17pin plug driver's kick.
Pin #5: This wire is the (-) trigger input for the door trigger. Black/white wire on keyless door lock control unit.
Pin #6: This wire is the (+) input for the door trigger. NONE
Pin #9: this wire serves as the Tachometer input. Blue wire on Connector 204 in passenger dash panel.
Connector #4:
Pin #2: this wire is the (-) 200mA trunk release. Use with relay to get + output for black/yellow wire on keyless dor lock control unit.
Pin #3: This wire provides you with the capability of adding driver
Connector #1:
Connector #2:
Connector #3:
Connector #4:
Yes, hopefully someone will come around and help me out with this. When I get confirmation, I'll go ahead and install this with pictures and make a nice little DIY alarm thread!
sweet...
there are a number of threads out there w/ info on actual wire tie ins, but they are mostly all DEI cut and pastes.
if the search were up, i'd find you one. i'm sure i marked a couple w/ my keyword.
Thanks! Any help is greatly appreciated. I did some searching myself but have found mixes results, and none regarding remote start.
I PMed macgyver, hopefully he'll stop by and give feedback soon.
This might help - I thought I gave it to Philip to add to the FAQ
http://darksidesubs.com/alarm/S2000ALARM.htm
did you? ack. if so, i lost it and completely forgot about it... honestly, if you would have asked i swear i would have said never saw it.
my bad.
