Can i put a 12" SWR Alpine sub in and keep the h.u. stock?
Sure. Get lucid's rear speaker harness, and instead of running the new rear channel output wires to a set of rear speakers, run them to an amp with speaker-level inputs (or use a line-output converter to give you RCA's). Run your sub off of the above amp. Just realize that when you use the fader on the HU, you will be increasing/decreasing signal going to the sub rather than a set of rear speakers.
