Biometric Immobilizer
OK so give us some details or is it still a sneak peek...lol.. BTW that's a great idea in case someone tries to jack you at a light, just turn your car off and run and they aint goin no where.
Well I was going to post more pictures tomorrow since they are on my buddies camera. I already installed the unit. Basically it is the fingerprint reader that goes to a little ecu. This ecu requires power and a 12v lead from the brake switch.
There is also a relay which is what breaks the connection in the chain be it fuel pump, starter signal, or ignition signal.
The ECU and relay communicate wirelessly so therefore you can place them in two different locations and no one would be able to easily figure out they are connected. Also the relay looks like a standard automotive relay.
Originally Posted by dr.darkness,Mar 6 2008, 05:11 PM
OK I'll wait for pics and more details. Most creative mod I've seen in a long time Justin.
soooo basically you pull this ECU out , and hook up the starter wire and you could steal the car anyways? or you just connect all the wires back together at the ecu part??
