Aux plug in trunk
Aux plug in trunk
Hi I'm trying to find the plug for the c/d shuttle in the trunk. I removed the cover for the spare, and moved the over cover. I don't see it can someone post a pic please.
I have seen it on older models maybe Honda no longer has it on newer s2000. MY08 Thanks Tony
As far as I know it should be there. Look at step 16 on the following pdf to get an idea of where the cable should be.
http://www.bernardiparts.com/Images/Instal...nk_AII38249.pdf
First I would like to thank all of you for the help. I think on Canadian models there is no aux plug in the trunk. I guess the only way to find out is to remove the radio and see if there is a white plug or not. I have check all the harnesses in the trunk. There is on going to the gas tank single harness I have followed it with my hand all the way into the car. And the other is going up some where into the shelf. If anyone sees it in the pic please let me know
Guess you're right, I don't see it in that photo. I will try to get a photo of mine for you later tonight. On my 2007 it was on top of that carpet padding to the left of the tire covered in tape.
