Audio Project - Speakers, Sub, Bass Shakers
Old 08-15-2010, 05:57 PM
  #71
WarTowels's Avatar
Haha I turned on the DCI's "tap" feature, which expands the use the of dash controls and I was quite confused at first because the button layout/functions had changed on me!
-Towels
Old 08-16-2010, 10:54 AM
  #72
WarTowels's Avatar
This is unrelated, but I need to vent-
The shop that repaired the ding left a fat drip on the paint they did. They are claiming it was there already... Yes. A multi-level drip on my factory paint job. Good call.
Going to go postal on their asses.
-Towels
Old 08-18-2010, 10:02 AM
  #73
tntrac's Avatar
I recently had my rear bumper resprayed. They over sprayed a 1/4" spot near the fuel cap. I had to use compound to rub it away. I didn't want to come back to the shop.
My box. I am almost done. Just need to sand and carpet. I was going to build a ring around the sub to make it flush but my router tip was so worn out, I skipped it.
tntrac
Old 08-18-2010, 12:23 PM
  #74
WarTowels's Avatar
Looks like your making good progress!
I'm waiting for my sub to get in to do final test fitting before carpeting.
-Towels
Old 08-19-2010, 06:53 AM
  #75
WarTowels's Avatar
My woofer came in today, so I will be test fitting and performing some final adjustments and hopefully I left myself enough carpet to get this bad boy done!
Now keeping it from moving in the car... I haven't figured that one out. I was thinking Velcro somehow... It is QUITE snug as is, but with the vibrations of the woofer I could imagine it shaking a bit.
-Towels
Old 08-19-2010, 07:16 AM
  #76
irv_usc's Avatar
velcro is pretty good. there's some high grip version that holds super strong.
you can also cut holes into the side panels and run straps through.
Old 08-19-2010, 07:18 AM
  #77
TrackStar's Avatar
Behind the carpeting, there is a part of the frame that runs along the fender side with holes drilled in it. You can drill a hole thru the back of the box and put a bolt thru. I would get a bumpstop and cut it shorter and put a piece on the inside and outside of the box and slicone it.
Old 08-19-2010, 11:04 AM
  #78
WarTowels's Avatar
^ I like that idea.
I will investigate that.
-Towels
Old 08-19-2010, 01:37 PM
  #79
WarTowels's Avatar
Good call. I think I will use the lower push pin location and just replace it with a stainless steel bolt, and drill a hole in the box, use a thick rubber grommet on either side of the bolt. Then possibly silicone it from the inside.
-Towels
Old 08-22-2010, 07:51 PM
  #80
WarTowels's Avatar
Box is pretty much done, I want to put some resin around the terminals to secure it, drill some pilot holes for the sub, and that's about it.
FYI, I have a JL grill already for the sub, but that will go on last.
Here's some picture:
-Towels
Quick Reply: Audio Project - Speakers, Sub, Bass Shakers
