Audio Project - Speakers, Sub, Bass Shakers
#91
The proper setting can be found only while the radio is in BT hands-free mode (page 48 of the pdf manual). The setting to adjust is "Bluetooth HF/Audio", where you can select "Front" or "All". Even though the manual describes this for voice, is applies to both voice and audio streaming.
#93
(recalling from memory)
your phone has to be connected then go into bt settings
then i believe u push the center circular main button to bring up audio settings
look for Bluetooth HF/Audio"
then u can toggle to change the speaker settings from front to all
i can try it when i get off work and tell u exactly
#94
I appreciate it. I'm going to go give this a try right now.
EDIT: Hey hey hey! That did the trick! Thanks a ton for pointing that out, saved me some painful time talking to customer service.
Thanks,
-Towels
Thanks,
-Towels
#96
Well I seem to have another problem.
My car keeps dying, and needs a jump or a charge.
So I see that one of two things are happening.
Either the voltage display distribution block is sapping enough energy displaying the voltage to deplete the battery - or the battery is no good.
I should check the date on the battery and have it tested I suppose.
-Towels
-Towels
#99
I mounted the mic by my right knee, on the lower part of the dash.
I've only attempted one call, on the highway with the top down. I could hear them, but they could not hear me. I have no adjusted any of the settings or tried again since then...
-Towels
-Towels
