AP1 only BT adapter for OEM cd changer
Old 10-21-2024 | 06:05 PM
  #21
9K2RDLN's Avatar
Originally Posted by thoiboi
I was researching it and it looks like their YT-BTM module has a 4 pin connector: https://www.aliexpress.us/item/32568...Cquery_from%3A
Some have the 4 pin, they have a bunch of different models. I can confirm this one works for AP1 S2000's: https://www.aliexpress.com/item/1005...3ea7f19c8Q4Q9e
I can't get the TP link bluetooth module going. Seems you need to download drivers on to it which are only available for PC and not Mac. The UBT module it comes with seems to be stable now. I'm guessing it's a bad connection, I'm going to tape it and see if that helps.
Old 10-22-2024 | 01:36 PM
  #22
9K2RDLN's Avatar
Last update from my end. The connectivity issues have been resolved. For anyone looking for an AP1 bluetooth option in the future, I can share that the Yatour M06-HON1 can work seamlessly if you replace the bluetooth module.
I'm using a UGreen bluetooth aux cable I'm using a UGreen bluetooth aux cable
and the connection has been rock solid.
Old 10-26-2024 | 07:23 PM
  #23
super-S2's Avatar
Also reporting back, the GROM unit is installed and it works really well. We zip-tied the grom box under the driver side dash in an elegant way with two zip ties. You can’t see it, and there is no tension on the wires. It looks OEM. This set up also allows for easy access to the GROM box if needed.
All the dash audio controls work exactly as expected. The sound is very good to me, definitely better than the radio.
So far the only two negatives I can tell are:
1) a mild low volume speaker “pop” when it connects for the first time. Do you know what I mean?
2) A couple times while driving the BT disconnected and I had to reconnect. I’m not sure if it’s because of siri reading map directions or what, I’ll try to figure out a pattern as time goes on.
Really happy with it so far!
Old 10-29-2024 | 09:35 PM
  #24
thoiboi's Avatar
Thanks for the link! the model i found had a 4 pin, didn't see the one with the USB input!
CrAzYNeSs
04-05-2008 06:07 PM
MyEeek
Socal Swap Meet
02-17-2008 08:03 AM
sohchatch
10-03-2006 06:08 PM
Danny_Spain
06-19-2006 10:19 AM
Reds2kracer
08-02-2005 07:53 AM
Quick Reply: AP1 only BT adapter for OEM cd changer
