Anyone running these speakers?
Old 06-22-2017 | 01:30 AM
rpmgem's Avatar
Default Anyone running these speakers?
About to upgrade my stock speakers on my AP1.
Thinking of buying these Alpine speakers http://www.bestbuy.com/site/alpine-6...?skuId=1807251
Will be replacing the stock radio with an Alpine CDE-143BT headunit as well. I'll be using speaker connector harnesses for the tweeters so I don't have to splice. Is there a separate wire for the 6.5" speaker? I'm new to installing speakers and want the install to go smooth. Thanks
Old 06-22-2017 | 03:26 AM
windhund116's Avatar
Yes, there are paralleling wires between the crossover, mid-range/woofer, and tweeter. You'll need to fashion an adapter plate between door mount and 6-1/2" speakers.
These are nice speakers. Cleaner tone, than the OEM ones. Esp the tweeter.
Old 06-22-2017 | 07:30 AM
oth's Avatar
oth
Those Alpine SPS-610C speakers are not very efficient (sensitivity: 88 dB/1W/1m) and would probably be better used
with an external amplifier, especially in a noisy ragtop. FYI a speaker with a sensitivity of 88 requires twice as much power
as one with a sensitivity of 91.
Old 06-22-2017 | 11:50 PM
rpmgem's Avatar
I'm not sure if these come with a crossover, just tweeters and the two 6.5 speakers. How would they be wired? As for the adapter plate, I'm thinking of using the Modifry 6.5" speaker rings.
Old 06-23-2017 | 03:34 AM
Those come with crossovers. I made speaker adapter rings from thin plywood.
Old 06-23-2017 | 03:53 AM
rpg51's Avatar
Every time I see a thread like this I start thinking about upgrading my system. I have a new Alpine head unit installed, otherwise stock. I tend to listen to softer rock - like maybe Lucinda Williams stuff and such with sweet rich and fat guitar work, modern folk, progressive bluegrass, jazz, etc. Not heavy metal and not classical. I play music myself a bit and so think I have a decent ear and I like to be able to hear nice clear tone from each instrument.
I don't want to go hog wild here - but I am vaguely unhappy with the sound I am able to get out of this system right now. I use the Alpine iphone app to adjust the tones and that does work well but still - not an extremely rich experience. I realize that the S is inherently noisy and I wonder if throwing money at this system is every really going to make a significant improvement.
Any suggestions? Add small powered sub? Add upgraded speakers in door or stick with stock? Add small Alpine underdash amp? Nothing?
So far all I have done is to change the head unit and I did that mostly to get the ability to stream from my iphone.
Old 06-23-2017 | 05:58 PM
If you are satisfied with what sources your current unit has available, maybe a powered subwoofer is all that you need. Good ones make a big difference.
Old 06-27-2017 | 01:22 AM
lovegroova's Avatar
UK Moderator
It's also well worth adding sound deadening to the doors (as well as other areas if you wish) as it makes a good improvement for very little outlay.
Mugen_is_best (02-27-2023)
Old 06-27-2017 | 05:02 PM
Sound deadening the doors is great way to improve sound. I used Dynamat.
https://www.amazon.com/Automotive-Deadener-Deadening-Dampener-Genuine/dp/B0172AFD66/ref=sr_1_1?s=automotive&ie=UTF8&qid=1498608135&sr=1-1-spons&keywords=dynamat&psc=1 https://www.amazon.com/Automotive-Deadener-Deadening-Dampener-Genuine/dp/B0172AFD66/ref=sr_1_1?s=automotive&ie=UTF8&qid=1498608135&sr=1-1-spons&keywords=dynamat&psc=1
Old 06-29-2017 | 04:30 AM
rpmgem's Avatar
Thanks Im going to pick up the ones with Poly-Mica cones and they come with ring adapters. I also ordered Honda speaker harness adapters so I don't have to splice the factory harnesses. Should be an easy plug and play
