Another Headlight issue - Strobe light effect
EDIT: FIXED IT.
So I tried almost everything I can think of. Did a search and doesn't sound like anyone has the same issue as I do.
My passenger (right) headlamp started to flicker, As in it tries to ignite over and over and over again so you just see a spark and a short light projection (ignites maybe once every half a second, and it continues to tick). It keeps doing this and never shuts off. When I turn the high beam on, it completely shuts off (when the light switch is on). I thought this was a ballast issue, so I swapped in a new ballast and bulb and the problem still persists.
I checked the fuses in the engine bay to see if any of them are blown and they seem to be fine. Anyone got any ideas?
I narrowed it down to a grounding issues or something else.
I forgot to mention - it acts like a weak strobe light?
Does anyone know where the connection to the ballast is grounded to?
Heres the picture of hte problem:
take the HID capsule from your drivers side light and put it in the passenger side and then turn on the lights. If that fixes it then you need a new bulb. If not, you probably need a new ballast. When there is a problem with the HID system a small amount of current will flow through the high beam bulb so you still have light on the road.
I bought a cheap fuse tester and tested ALL my fuses, turns out i missed the most important fuse that was part of the headlight. Also checked all the grounds with a multimeter. You can find a write up on how to test your grounds, If you guys noticed, the S2000 has a million grounds all over the car =(
