amp worth it?
#21
Originally Posted by dyhppy,Aug 7 2006, 03:10 AM
so bottom line, an amp will NOT make the sound at regular volumes clearer, but will keep the music clear at higher volumes ONLY?
An amp is like steroids - now you're Arnold Schwarzenegger and that 50lb is easy to lift and balance over the egg, but 500lb is hard. So with an amp, your system can handle the volume because it has lots of strength. 5 lb is easier now, so the sound quality is better not just at 5lb, but all the way to 50lb.
An amp makes your music better because "regular" volumes increase from the 5lb point to the 50 lb point - wider range.
