Amp wire through the firewall?
There's a wire harness under the battery that goes through the firewall. It's tight to reach under there, but I was able to do so without removing the battery. I used a long, thin, screwdriver to puncture the boot, then simply pushed the wire through from the engine compartment side. USE CAUTION so you DO NOT damage the wire harness!!
Fusiondynamics
02-03-2005 09:51 PM
