Amp sub help
Old 11-10-2009, 02:33 PM
  #21
Neuman04's Avatar
Plug and play. Ever wore is color matched on the harness the stock hu works fine just tried it Everything but the solid blue snt wire and the white orange illum wire are connected
Old 11-10-2009, 02:48 PM
  #22
DFWs2k's Avatar
ok....well if stock radio is working by plugging it in....you checked volume and fade/balance settings?
Old 11-10-2009, 02:52 PM
  #23
Neuman04's Avatar
Volume with the stocker is up and sounds fine bass and Tre are up but would that make a diff
Old 11-11-2009, 12:15 AM
  #24
DFWs2k's Avatar
no those would only change things with that headunit...i was talking about the settings on the aftermarket HU since that is what is giving problems....
are you sure that HU is good?
Old 11-11-2009, 05:27 AM
  #25
Neuman04's Avatar
Funny you should ask, i swapped it with a different one and it worked. It was odd that it would turn on and function propley without sound no? Also, i think the amp is toast. I connected it directly to the battery to test and it was still in protection mode. Even got a clean ground behind the fuel filler tube.
Old 11-11-2009, 05:53 AM
  #26
DFWs2k's Avatar
what brand was the amp?
Old 11-11-2009, 06:46 AM
  #27
Neuman04's Avatar
The amp came out of my friends car working. I havent had it 1 week and just tried to install it. is it really possible its broken?
Old 11-11-2009, 06:51 AM
  #28
Neuman04's Avatar
It's a kicker zx400
http://signature.crutchfield.com/s_2068ZX4...1.html?tp=27743
Old 11-11-2009, 08:45 AM
  #29
oth
oth's Avatar
power up the amp without RCAs or speaker wires hooked up.
if it goes into protect, you have a bad amp or inadequate power/ground
connections.
if not, hook up RCAs - if this causes it to go into protect, there's your
likely problem
if not, hook up speaker wires - if this causes it to go into protect, you
probably have a short in your wiring or your sub has too low impedance
Ryans2kGPW
07-15-2010 12:28 PM
netanderthal
10-22-2007 01:57 PM
jojipoji
04-07-2004 08:05 AM
NFRs2000NYC
06-30-2003 11:03 AM
145
07-09-2002 06:06 PM
Quick Reply: Amp sub help
