Amp sub help
Old 11-09-2009, 09:24 AM
Neuman04's Avatar
How could the ground make the whole system not work?
Old 11-09-2009, 09:36 AM
DFWs2k's Avatar
most amps will go into protect mode if they aren't getting a good ground, if the amp isn't working, then the sub won't work.
are only the sub and amp not working? or are your speakers not working either? is your amp only going to your sub?
Old 11-09-2009, 09:45 AM
Neuman04's Avatar
amp is only going to the sub, other speakers are working
Old 11-09-2009, 09:49 AM
DFWs2k's Avatar
ok, then since that amp is in protect mode, it wouldn't be sending a signal to the sub, which is why those 2 things (amp and sub) wouldn't appear to be working.
so, check your ground.
Old 11-09-2009, 10:20 AM
Neutered Sputniks's Avatar
^^What he said
Old 11-09-2009, 10:38 AM
Neuman04's Avatar
Thanks guys! I'll check as soon as i get home! Gotta love S2KI!!!!
Old 11-10-2009, 05:07 AM
Neuman04's Avatar
Ok new problem. I tried to reconnect my Hu with the same exact harness yesterday. No sound from ther speakers, put the stock hu back in works with no problem. What gives?
Old 11-10-2009, 11:08 AM
DFWs2k's Avatar
were the harnesses fully clipped together ?
Old 11-10-2009, 01:11 PM
Neuman04's Avatar
To my knowledge it was the stereo got power and played a cd but i got no sound
Old 11-10-2009, 01:52 PM
DFWs2k's Avatar
did you get one of those plug and play harnesses or did you hack up the honda harness?
Quick Reply: Amp sub help
