amp stopped working?
Old 08-13-2007, 12:55 PM
DDuds2k's Avatar
well, neither amp is playing anything. So i figured if the speaker amp blew, shouldnt the sub still be playing the bass b/c the sub amp wouldnt have blown also? Pretty sure the blue light is coming on with the subwoofer amp, so it should be powering up, ill go double check in sec.
What I did was take the voltage meter and touch it to the area the remote wire was leading into. It read power was reaching the amp, and that it was at 12v. So, maybe it was the meter just reading power coming from the remote wire and not the amp...In other words, How can I check to make sure the amp is recieving the power the remote wire is sending? How do i test for this? Did i do it correctly?
Old 08-13-2007, 01:01 PM
imdarkrider's Avatar
put the black plug - ground , on the ground of the amp... take the red - power to the power wire... if your reading 12v your good , now turn the car on , take the black to groun again , and then the red to the remote... if your reading 12 your good... if your not then your remote wire is bad. if your not getting power to main power wire then you've got a bad fuse somewhere...
Old 08-13-2007, 01:25 PM
DDuds2k's Avatar
so...the sub amp light is not on either. Does this mean no power is reaching the amps from the battery? OR does it mean the HU is not supplying any power to the remote turn on?
Old 08-13-2007, 01:38 PM
if you've got a meter , metere the main power wire and if it's got 12 then it's your turn on wire.
Old 08-13-2007, 01:55 PM
Cubs2k's Avatar
How long has your system been installed?
Someone else did the head unit right?
What source are you trying to play? Radio? CD?
Old 08-13-2007, 04:59 PM
DDuds2k's Avatar
ACtually I decided to dissasemble most of my trunk and I re-screwed in all the wires again, check the power going to the remote wire and power line. Getting power to both. Turn on the radio. And it works! Dont know why it wasnt, maybe just a bad connection with the remote wire. What a pain. Electronics are so bitter sweet.
Old 08-13-2007, 05:13 PM
multimeters work magic if you use them correctly :-) congrats on getting everything fixed!
Silver5656
07-06-2010 09:45 AM
Boost76
02-15-2008 07:35 AM
chunkotron
11-13-2007 12:01 AM
sleeze
10-01-2006 06:34 PM
TR-S2K
05-07-2005 04:54 PM
Quick Reply: amp stopped working?
