Alpine DVA-9965 Hu
Old 03-22-2007, 07:47 AM
VorlonDrow's Avatar
Default Alpine DVA-9965 Hu
Ordered my Alpine DVA-9965 yesterday. One question though, I have heard a lot of the newer head units have extra inputs for OEM steering wheel/dash controls. Is that the case here or should I order the DQube or Modify DCI? If so which is best for this HU? BTW, anyone else using this HU?
Old 03-23-2007, 05:53 AM
SebringDemon's Avatar
iirc, this unit has the mini din jack for control.
its been a while since i played with this HU so im not 100% sure.
Old 03-23-2007, 05:10 PM
b16horse's Avatar
where did you order the headunit and how much did you pay if you dont mind. i was thinking about getting this headunit. what type of amp are you running it with
Old 03-24-2007, 07:55 AM
VorlonDrow's Avatar
PM Sent. Issue I am having now is where to install the amp. I dont mind losing my spare but I am moving to CO (from TX) in a few weeks. Knowing my luck, I will need that spare along the way.
I think the best bet is going to remove the panels that line the trunk to free up some room...anyone have pics of the trunk sans panel?
Old 03-27-2007, 08:21 PM
VorlonDrow's Avatar
It begins!
Old 03-28-2007, 09:33 AM
DDuds2k's Avatar
do a search for installs...you will see many places for amp install. If looking for invisible install- Good candidate is the in the spare tire well, but you lose the tire if you dont mind. If you can find an amp to fit...you can put it next to the tire near the gas tank...
Do a quick search, you'll find everything you need.
Old 03-28-2007, 09:44 AM
DDuds2k's Avatar
https://www.s2ki.com/forums/index.ph...ic=473951&st=0
heres a really good link
Old 03-28-2007, 11:16 AM
VorlonDrow's Avatar
Thanks for the link! I have been pouring through that thread for a while. My amp *might* fit over the gas tank but I am concerned about cooling for the amp...and having a source of high current above my gas tank.
Old 03-28-2007, 12:21 PM
oth
oth's Avatar
if memory serves me, I think as long as the amp is less than about 16" long
and about 2.5" thick, it should fit above the gas tank. cooling will depend
on amp design, but a number of us have been running this way without
problems. fwiw, the vents behind the seats are there to vent the trunk, so
there is actually some airflow.
Old 03-28-2007, 12:30 PM
VorlonDrow's Avatar
amp measures 12.75" x 10.25" x 2.25" so it may actually fit. Looking for more of an invisible install if I can manage.
Quick Reply: Alpine DVA-9965 Hu
