ALPINE CDE-136BT
ALPINE CDE-136BT
I fancy this head unit
ALPINE CDE-136BT
also want to use the dash controls. Will a modifry unit work? Which type of the 2 modifry units shall i get? I have searched using the website instructions to no avail?
ALPINE CDE-136BT
Fairly certain you can use the wired DCI. Check on the specs of the alpine unit. If there is a remote port on the back of the receiver, use the wired DCI.
I have the 137 and used the wired DCI.
It's a bit buried but this page is linked from the DCI FAQ:
http://www.modifry.com/products/dci/...patibility.htm
The CDE-136BT page at:
http://www.alpine-usa.com/product/view/cde-136bt
says:
"steering wheel remote" compatible, which is the feature that allows the Wired DCI to control the head unit
says:
Steering Wheel Remote Ready
I went for the 147BT for the rear USB port and tune-it. It also has a separate sub out and 3 digital crossovers. Works great with the wired alpine modifry. Best upgrade to my ride, along with the alpine ktp445a, 2way components, and sub with amp.
Does look like the 147bt is better. Im getting bogged down in all these different alpines, does anyone know any good sites for reviews of head units?
Whats the actual advantage of a rear USB port?
Originally Posted by switchmorgan
Does look like the 147bt is better. Im getting bogged down in all these different alpines, does anyone know any good sites for reviews of head units? Whats the actual advantage of a rear USB port?
