alpine amp + speakers, still sounds like crap
Old 08-16-2014, 06:47 AM
  #61
UK Moderator
UK Moderator
lovegroova's Avatar
Originally Posted by hand banana
Originally Posted by PorgyS2K06' timestamp='1408185123' post='23289387
Wait what. Took what power? Nothing should be coming out of the fuse box. You should have a power wire, 8g or bigger, coming from the battery and 12v turn on coming from head unit.
an 8ga wire would be overkill for this, i the power lead coming off of the amp is barley 12ga, i will try running a 10ga directly to the battery before i do anything
Originally Posted by lovegroova
I mentioned this 10 days ago - see post#44
i totally missed that
Don't think you did - see post #45 lol
Old 08-16-2014, 06:59 AM
  #62
hand banana's Avatar
Lol guess your right! Hahah well either way ill give that a shot before anything else
Old 08-16-2014, 09:28 AM
  #63
PorgyS2K06's Avatar
Eh was drinking late last night when i randomly checked this so yeah, didnt have recollection of what was said. I myself am a fan of overkill when it comes to wiring. I'm running 2/0 to my distro block. Would rather have bigger than run it again if I needed to upgrade.
Old 08-30-2014, 11:22 AM
  #64
s2kcol's Avatar
I have the Alpine KTP-445 amp, bridged to 90w, powering two Polk db6501 components with 100w RMS, 300w peak. This all comes from an Alpine CDE-133BT head unit. It doesn't sound good--not at the volume I need. Today, I am installing an Alpine PDR V75 amp, and I will bridge it to push 200W to my speakers. I will have the gains and the volume low, but I think this is going to vastly improve the sound. I think that KTP amp just doesn't push enough power to my speakers without clipping. Amp specs are notoriously lower than advertised, and speaker specs are often a bit higher, so it's extremely likely that my Polks just aren't getting enough power.
Will check back in later to let you know how it sounds.
Old 09-09-2014, 01:14 PM
  #65
PorgyS2K06's Avatar
This isn't entirely true. Most commonly the problem is they go by max power handling numbers rather than rms power. Very common among lower end brands (Lanzar, Boss, Pyramid, etc) Alpine is pretty true to their ratings. They do rate their amps at 14.4 volts as per CEA certification requirements however depending one what you got running the amp might not be seeing 14.4. You'll see companies rating at 13.8 more now since its a lot more realistic unless you have some beefcake electrical.
Old 11-26-2014, 09:43 AM
  #66
DaGou's Avatar
How did it sound?
HondaS
05-04-2015 11:13 AM
2001e46
09-24-2006 05:21 PM
sgribble
07-16-2003 07:45 AM
sgribble
07-15-2003 08:49 PM
F1 Tech
09-04-2001 07:34 AM
Quick Reply: alpine amp + speakers, still sounds like crap
