Alarm Remote vs Keyless Remote
Recently picked up a MY03 with an OEM alarm (has the Valet button, LED behind the e-brake) but was missing both remotes.
After doing some searching, I found that there are two different remotes available, and both would work. But if I got the keyless remote it wouldn't operate w/the alarm, only the doors.
The keyless remote and the alarm remote both have 4 buttons, but the only difference is that the trunk button on the keyless remote is an "option" button on the alarm remote. From some threads here I found a FCC ID# that belongs to the keyless remote: E4EG8DJ. I also found that the alarm remote part number is 08e61-s01-1m0-01. What is the keyless remote part number? And is the alarm remote FCC ID# the same as the keyless remote FCC ID#?
I found an auction on eBay for the alarm remote part number, but it says it's for a Civic, and the FCC ID# is A269ZUA101. Is this the correct one?
Could someone with the OEM alarm remotes verify the above? I would like to get a set of alarm remotes and I want to make sure I get the correct ones. So far I've only seen the keyless remotes on eBay.
usmarinedelta
09-16-2015 05:59 AM
STL
08-12-2002 01:30 PM
