Airbag SRS Light Is On
I took the steering wheel off. Put it back a day or so later, and now I have that wonderful light!
How do I get rid of it?
I tried resetting the ECU... etc...
Will and OBD2 reader do the trick?
you can go to your local dealer and buy this wire plug that connects to the MES 2P yellow connector under your dash. the number for that plug is: 07PAZ-001011A. i think it cost under $15. you have to go through a series of plugging and unplugging that connector when the SRS indicator turns on/off so that you can erase the memory from the SRS unit. i have recently done this when i took off my dash, and it's because you have to unplug your battery before you unplug your airbag. the process is explained more in the service manual on p.23-19. i hope that helps.
Thanks guys
Im trying to order the SCS Service connector
but my dealer has no idea what im talking about...
i gave them that part # but they still cant find it...
also... any ideas where to get a copy of the service manual? and the Helms manual?
https://www.s2ki.com/forums/index.php?showt...&#entry11569510
Did it with a paper clip in under a minute
To other members reading thing....NEVER turn off an SRS light by yourself. Always go to the dealer and get it checked out. If there is a problem with your airbags, you might want to know what it is.
Ya but i did know what was wrong with it. I unplugged it... then plugged it back in...
there is no defect of problem, only a stubborn computer sys in the car
lol
and **** paying $95 for the dealer to do what i did in 9 seconds...
lol
