2004 Speaker Rear Speaker Harness
Old 06-18-2005, 07:59 AM
asn
asn's Avatar
Default 2004 Speaker Rear Speaker Harness
I have a 2004 S2000, and would like to find the rear (headrest) speaker harness that just plugs into the 4 wire harness that is hanging off of the normal harness.
I could go with the Lucid one, but I believe that shares the same wires are the front speakers, and doesn't give you the front/back fader.
I don't want to buy the kit from honda, because the speakers suck, and they won't sell the harness by itself.
Anyone know where to find one?
Thanks!!
Old 06-18-2005, 08:07 AM
mwd473's Avatar
The lucid one does allow use of the front back fader as well as the dash controls.
Old 06-18-2005, 08:47 AM
asn
asn's Avatar
that's good to know, but I'd still rather use the honda one. Anyone have any idea of where to get one?
thanks
Old 06-18-2005, 09:52 AM
Bass's Avatar
i don't think anyone sells just the harness
why not just splice into the wires??
Old 06-18-2005, 11:49 AM
asn
asn's Avatar
I think I'll probably end up splicing into the them. Thought it would be cleaner if I used a harness. Clean is good!
Old 06-18-2005, 10:11 PM
steven975's Avatar
the lucid one is probably the best bet.
while the honda one may look nice and perfect, functionally they are exactly the same. all it does is provide an "extension" to the stock harness while also adding rear wires to use. All model years have rear speaker outputs, but the OEM harness lacks the pins.
Old 06-19-2005, 02:03 PM
Treedriver's Avatar
I went to a local scrap yard and had them cut the radio plug from a civic, leaving about six inches of wire with the plug. I had to let them take my radio to be sure the plug was the same. Then I removed four wires from the Civic plug and inserted them in the correct location in my plug. Worked great and I just spliced wires to run to the rear of the car. I paid $ 10.00 for the civic plug.
Old 06-19-2005, 03:49 PM
mwd473's Avatar
rear speaker
Old 06-19-2005, 04:00 PM
mwd473's Avatar
another alternative
No need to take out the HU on the '04. There's a 4-pin connector by the driver's side panel of the stereo that is used for the CD changer. Check this install guide for the location (page 11 step 56).
http://www.handaaccessories.com/S2000/s2kheadrest.pdf
I just cut off the connector and soldered the wires on for my rears. Here's the wiring colors:
Red/Yellow (Passenger Rear Speaker (+))
Brown/White (Passenger Rear Speaker (-))
Blue/Yellow (Driver Rear Speaker (+))
Gray/Red (Driver Rear Speaker (-))
This post has been edited by Scanman on Sep 16 2004, 07:45 PM
Old 06-19-2005, 04:18 PM
Bass's Avatar
good advice mwd473 except it's not for the changer it's for the rear speakers and this is only in the >=04s
check out page 11
Quick Reply: 2004 Speaker Rear Speaker Harness
