Yet another Suspension Q (FA500s vs Ohlins?)
definitely give the karcepts 1WNR MCS a consideration if going all the way to FP Spec. You're in the same ballpark, plus the mcs 1wnr's give you the option to convert to doubles with remote reservoirs.
Bullwings (01-01-2024)
I had the FP Sports but was not impressed with the valving at all and have since revalved them to FP Spec valving. They were too soft and I needed to run them almost full stiff to control the rebound otherwise it would feel a little floaty but then they would be a bit harsh. I'd say go with standard Ohlins or step up to FP Spec
If you’re looking for a race shock, the FPSpec Long Stroke is the way to go. For a little cheaper, we do a full revalve and respiring of the Road and Track kits (short stroke) - which we have as the Race Valved 14/12kg set, using the same race winning valuing curves developed for our FPSpec Long Stroke kits - but a bit more affordable.
For a tamer / less hardcore HPDE setup that’s much more affordable, we offer the standard Road and Track with modified 12/10kg spring rates and lowering cups… that’s the most affordable of the Ohlins kits that’s track worthy… the 10/8kg are just too soft for serious track work, even with sway bars.
For those considering MCS… we’ve got something very very special coming… we’ll talk more about it shortly if you’re looking for a dedicated race shock that will top the MCS … can’t say much more publicly yet, but email us if interested info@sakebombgarage.com
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Also our current FPSpec Long Stroke are literally on SCCA and NASA 1st place podium winning cars across the country, they’re proven to win races. We’d be happy to back to back test a similar MCS versus our FPSpec Long Stroke for lap times at any of the Northern California tracks on a similarly setup car. We’re THAT confident with what we’ve built. Not to say the MCS are a slouch coilover… but we’re extremely impressed with the performance of what we’ve built with the Ohlins Patented DFV High Speed Blowoff, and patented temp correction valve in addition to many other features lacking in other coil overs. They are not only consistent first lap to last, they allow drivers to plow through mid corner bumps, dips, berms, etc without transferring this force to the chassis. There’s a reason top racers are running our hardware, but also a reason they keep it pretty quiet… our brakes and suspension are a huge performance advantage over the rest of the pack. With the new hardware coming, we believe we’re going to take this secret sauce to an entirely new level
__________________
__________________
Hopefully we were able to help you out… I think a lot of customers assume since the FPSport is more expensive than the Road and Track they are *more* track focused. But they’re actually more *street* focused for every day comfortable use. Yes, they’re absolutely traceable for fun HPDE track days, but you’re not going to win any races on them, they’re meant to balance street comfort for every day use with decent backroads and track performance. One of the big complaints for Phlins is the harshness of the R/T, which was the original starting point for our dedicated track developed curves - running much more compression and rebound. We’re about 30-40% less with the Sport kits, and with the higher spring rates we have more compression stroke and droop travel with the amount of stroke available in the rear (a softer spring requires more stroke to take up the same bump as a stiffer spring, so running a bit higher rate alleviates the compression stroke issue with the non-long-stroke shocks.
The FPSpec valving is so much better than the FPSport valving, I actually think its more comfortable on the street since the rebound has more control and you don't need to run them so stiff. I am very happy with the FPSpec re-valve, new springs, full floating top hats, and lowering cups I purchased from you. I'm going back to Buttonwillow later this month and can't wait to see how they perform
DefSport
08-04-2020 02:24 AM
DefSport
03-22-2017 11:06 AM
Jack_in_the_Box
09-03-2010 06:19 PM
